Hi all,
I’m experiencing a strange bug with my RB4011iGS+, which applies both to stable and the RC versions. When rebooting the device, the main bridge ceases all L2 communications until I connect a serial cable and disable, then enable the bridge via console. I am using a single bridge, a couple of VLANs, DHCP and an IPSEC tunnel to NordVPN - nothing too intensive.
If I reset the router to factory defaults and reboot it with the default configuration, this issue does not occur. If I configure it from scratch, the issue will re-occur. Attached is my configuration.
Any ideas?
Thank you
Configuration.rsc (11.2 KB)
