RB4011iGS+ panics on boot
I have a RB4011iGS+ which I’ve wiped and upgraded to RouterOS 7.1.1. It was working perfectly yesterday until I rebooted it in error via the UI, and now it refuses to load the kernel image - see below. Bootloader is v7.1.1.
I have a separate, identical unit which is running fine. Is this likely to be a hardware issue and I’m just unlucky that it hit me mid-way through configuration?
loading kernel partition 0... OK
setting up elf image... OK
jumping to kernel code
opendir[    0.823023] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000000
[    0.831193] CPU: 0 PID: 1 Comm: init Not tainted 5.6.3 #2
[    0.836580] Hardware name: Annapurna Labs Alpine
[    0.841195] {bf05ff2c} _stext+0x97c4/0x4488b8
[    0.845545] {bf05ff34} _stext+0x4350a0/0x4488b8
[    0.850068] {bf05ff44} _stext+0x19acc/0x4488b8
[    0.854503] {bf05ff6c} _stext+0x1b8f0/0x4488b8
[    0.858939] {bf05ff84} _stext+0x1ca04/0x4488b8
[    0.863374] {bf05ff9c} _stext+0x1ca74/0x4488b8
[    0.867815] CPU3: stopping
[    0.870521] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 5.6.3 #2
[    0.876342] Hardware name: Annapurna Labs Alpine
[    0.880954] {bf09bf34} _stext+0x97c4/0x4488b8
[    0.885302] {bf09bf3c} _stext+0x4350a0/0x4488b8
[    0.889824] {bf09bf4c} _stext+0xbf10/0x4488b8
[    0.894172] {bf09bf64} _stext+0x1b4650/0x4488b8
[    0.898694] {bf09bf7c} _stext+0x1acc/0x4488b8
[    0.903042] Exception stack(0xbf09bf80 to 0xbf09bfc8)
[    0.908085] bf80: 00000894 00000000 00000894 801142a0 bf09a000 00000008 80903e24 80903e60
[    0.916247] bfa0: 0000406a 412fc0f4 00000000 00000000 00000000 bf09bfd0 80106f80 80106f70
[    0.924406] bfc0: 60000013 ffffffff
[    0.927889] {bf09bfcc} _stext+0x6f70/0x4488b8
[    0.932238] {bf09bfd4} _stext+0x3a108/0x4488b8
[    0.936672] {bf09bfec} _stext+0x3a398/0x4488b8
[    0.941106] {bf09bff4} 0x10246c
[    0.944243] CPU1: stopping
[    0.946948] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.6.3 #2
[    0.952769] Hardware name: Annapurna Labs Alpine
[    0.957380] {bf097f34} _stext+0x97c4/0x4488b8
[    0.961729] {bf097f3c} _stext+0x4350a0/0x4488b8
[    0.966251] {bf097f4c} _stext+0xbf10/0x4488b8
[    0.970599] {bf097f64} _stext+0x1b4650/0x4488b8
[    0.975121] {bf097f7c} _stext+0x1acc/0x4488b8
[    0.979468] Exception stack(0xbf097f80 to 0xbf097fc8)
[    0.984512] 7f80: 00000e2c 00000000 00000e2c 801142a0 bf096000 00000002 80903e24 80903e60
[    0.992674] 7fa0: 0000406a 412fc0f4 00000000 00000000 00000000 bf097fd0 80106f80 80106f70
[    1.000834] 7fc0: 60000013 ffffffff
[    1.004316] {bf097fcc} _stext+0x6f70/0x4488b8
[    1.008664] {bf097fd4} _stext+0x3a108/0x4488b8
[    1.013099] {bf097fec} _stext+0x3a398/0x4488b8
[    1.017534] {bf097ff4} 0x10246c
[    1.020670] CPU2: stopping
[    1.023376] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 5.6.3 #2
[    1.029197] Hardware name: Annapurna Labs Alpine
[    1.033808] {bf099f34} _stext+0x97c4/0x4488b8
[    1.038157] {bf099f3c} _stext+0x4350a0/0x4488b8
[    1.042678] {bf099f4c} _stext+0xbf10/0x4488b8
[    1.047026] {bf099f64} _stext+0x1b4650/0x4488b8
[    1.051548] {bf099f7c} _stext+0x1acc/0x4488b8
[    1.055895] Exception stack(0xbf099f80 to 0xbf099fc8)
[    1.060939] 9f80: 00000938 00000000 00000938 801142a0 bf098000 00000004 80903e24 80903e60
[    1.069101] 9fa0: 0000406a 412fc0f4 00000000 00000000 00000000 bf099fd0 80106f80 80106f70
[    1.077260] 9fc0: 60000013 ffffffff
[    1.080742] {bf099fcc} _stext+0x6f70/0x4488b8
[    1.085091] {bf099fd4} _stext+0x3a108/0x4488b8
[    1.089526] {bf099fec} _stext+0x3a398/0x4488b8
[    1.093961] {bf099ff4} 0x10246c
[    1.097108] Rebooting in 5 seconds..
Most probably you’re unlucky. And very likely you can revive your device by netinstall-ing it.
You’re quite right - I booted from another partition, wiped the first and it’s all working with the same RouterOS version.
Is there any way to dump the contents of the configuration file should this happen again, or even do a low-level binary dump of the partition?
I got this kernel panic second time…
One on v7rc3 in September - I considered it a coincidence.
Yesterday second kernel panic on v7.1.1 - after a power failure - power reboot.
I created SUP-70307.
It’s not possible to dump partition to file. The closest thing is binary backup … in certain circumstances even better possibility is configuration export, it creates text file (good for readability), but lacks a few things (users and passwords, certificates). Make sure you fetch those files (backup or export) off device before device gets into unusable state next tome …
