We have some problems with the RB4011iGS and its POE-OUT by using an unifi AP-AC-PRO.
Spec-sheet says 19.2W are supported by the RB4011 - the AP has a maximum of 9W.
After two days the POE doesen´t work anymore. What can be the reason for it?
Tested with a second RB4011 with the same result.
