I suddenly have this problem when I setup DHCP server on LAN interface of RB411 with ROS 3.16 loaded, where the PC gets 2 gateways, the first 0.0.0.0 and then my assigned 192.168.0.1
Delete/re-create DHCP not helping.
Is this a newly introduced bug?
Ekkas
Downgrade to 3.13 and all is ok again.
Since 3.14 we have been having problems with about 10% of our CPEs (RB133 & RB411) not letting through traffic. Can ping from WAN & LAN but no throughput. Downgrade to 3.13 and all is ok.
3.14 to 3.16 sucks, cannot trust it. Sometimes it works fine and then after a power outage, they stop working and you have to either reset & re-configure, or remotely downgrade to 3.13 to get clients up.
Have gone the support route, still not resolved.
Ekkas
Sergejs said that the intermittant issue passing traffic through with Firewall is replicated and should be fixed in 3.18
The DHCP issue is just as illusive. Had it twice with about 10 installs, so it’s not easily replicated. Seems like a certain routerboard does this as resetting/reconfigure didn’t work. Only software downgrade did.
I’m waiting for it to happen again, then I’ll send supout.
Ekkas
