Need more info.
How is the rb411 set up?
Is it access point, client cpe, point to point, etc.
Use torch on interface ether1 and see if the ip address you want to filter isn’t actually destination address. If that’s the case you need to change your rules and “in interface”.
Thanks Aug
sorry i forgot to mention the setup.
the rb411 is set up as client CPE and i would like to drop all invalid ip’s excluding the one’s on address list.
Thankyou
Thanks Aug
After doing as suggested by you, it worked.
why didn’t i saw that setting ? some one truely said “you dont’ need eyes you need vision to see”
Thankyou very much
sanjeev
