RB411 and Sierra MC8705 fotr GPS
The Sierra MC8705 is a 3G modem and GPS. I’ve conected it to a RB411 and I can connect to the intenert without problems. Great!
Now I would want to get some GPS data from the card. Sierra manual says that GPS information can be obtained using some AT commands, but I am unable to connect to the modem:
/system serial-terminal usb2 channel=0
stalls and waits until Ctrl-A Q is typed. Any other channel returns a “failure: no such channel” message
Does anybody know how to get GPS information from this modem? This is the output of /port print and /system resource usb print
/port print
Flags: I - inactive
 #   DEVICE NAME                    CHANNELS USED-BY                  BAUD-RATE
 0          serial0                        1 Serial Console           auto
 1   1:2    usb2                           1                          9600
/system resource usb> print
 # DEVICE VENDOR                   NAME                  SPEED
 0 2:1    Linux 3.3.5 ohci_hcd     RB400 OHCI            12 Mbps
 1 1:1    Linux 3.3.5 ehci_hcd     RB400 EHCI            480 Mbps
 2 1:2    Sierra Wireless, Inco... MC8705                480 Mbps
I appreciate any pointer.
I have the same problem!
Have you resolved?
I am trying but its imposible!!!
