RB411 and VoIP
Hi all,
We are using a RB411 with a AR5413.
We use them for VoIP with a QoS one for Data limited to 1M, and without limits to the voice traffic. We want to make a buffer (something like a jitter buffer) but we do not see how to do it with the wireless interface. We had been looking the forums and we think that it can be done with a Nstream interface.
Does someone know any way to do that?
jitter buffers should be configured on your VoIP software/hardware. Routers are the wrong place.
As for QoS, have you looked at the wiki?
We have our jitter buffers in the VoIP software, but we see that if we use an ADSL connection the sound quality has less problems than with the wireless connection. We think that the systems works better with a delay of 110ms (+/- 10ms) than with 5ms (+/- 5ms).
So we want to try to create a connection with a lower speed. The way to made that we think that has to be a buffer in the antena to create delay’s on the communication. Do you know if it is possible?
