RB411 continuos reboot !
Update my rb411 to new 3.2, after change wpa2 parameters and testing wds slave not work and do recyclic reboot.If I remove the radio card is ok.Tried new card same problem.
My first experience with Mikrotik nt is very good !
I have see in little time to much update !Probably 2.9.50 was best version but not is avaiable for 411 !
What kind of power supply and wireless card are you using?
Make sure compression is disabled. I ran into a continuous reboot problem with the RB411’s and compression.
-Gerard
Compression is disable, power is directly 12v 1a power supply, card is Nortel NTE-312aa, 5212 single band 5 ghz.Downgrade now with 3.1 and not reboot !
Interesting. Post your software configuration.
