Rb411, DCD or DTR enabled ?
Hi.
I’m new with Mikrotik Routerboard.
I Have recently buy a Rb411.
I got just a question about the serial port.
How enabled DTR or DCD pin ?
I got no voltage on these pins.
I search to use one of these pins for auto-reset an arduino board.
So it’s possible ? It’s no wiring to serial port ? It’s just configuration ?
Thanks.
The manual has a page about the serial connector pinout:
http://www.routerboard.com/pricelist/download_file.php?file_id=105
Most RB use only RX , TX and GND. Full RS232 signaling available only on RB200
RTS and DTR signals are not connected. Note that the device does not fully implement the hardware
(RTS/CTS) flow control,
Thx for reply.
Note for me next time : rtfm.
