Does the rb411 support hotspot and userman??
why not?
i then have a problem as i cannot access my userman… i type the ethers i.p e.g 192.168.1.1/userman, but it takes me nowhere…
did you enable and configure it?
iget as far as the hotspot log in screen,where do i check wich address i use to access userman???
you have to log in first ![]()
also you HAVE TO configure User manager !!!
superb, sorted. thanks
