Hi there. i Have a cable modem static ip and a routeboard rb 411 with level 4 with wireless pci that i would like to use as ap and since the modem cannot make dhcp i will use the routerboard to do this. I ve tried to setup like this but was unable to get it working. In wireless mode i select ap bridge mode? or what should i select?
thanks
Make sure you have level 4 on RouterBOARD, because it goes with level 3 by default.
Mode=ap-bridge is the mode you should select, it will allow connection for multiple wireless client to your wireless router.
yes i have level 4 on board and i have setup like you said and im unable to get sucess. I will post how i setup for you to tell me what i did wrong. thanks
