RB411 is unable to connect to ubiquiti powerbridgeM5
I bought a powerbridgeM5 which i want to use as AP to link two offices together. I configured the PBM5 as the AP and on the other end i used mikrotik RB411 as my CPE which is also 5Ghz antenna. When i scanned the network i could see the SSID of the powerbridgeM5 AP but cannot connect to it.
Can some one tell me if there is anything i am doing wrong?
Your response will be greatly appreciated.
disable airmax, as that’s a protocol that only ubnt devices can use.
And you have to disable both Nstreme and/or NV2 on the Mikrotik side too.
Rgds,
Mark.
Thank you guys very much for your response.
I still have a problem locating where to disable the airmax on the device. please tell me where i can locate it on the radio device.
Awaiting your response.
I’d look for that info on the ubnt site if I were you :smiley: . They have a forum too.
Since this is a MikroTik user forum, management look dimly upon ubnt support issues/replies made here.
Rgds,
Mark.
