RB411 kernel not found
updated RB411 to version 3.9 and now cpe doesn’t start more: Kernel not found
Used hyperterminal to upgrade again but the following messages appeared
file transfer ok
invalid upgrade file id
What can I do?
Any suggestion will be appreciated.
Thanks in advance,
levis
Use Netinstall
Thanks.
Hi, I ve a RB411 that fails to boot, it reaches till “jumping to kernel code” and get there.
I 've formatted the NAND and try to use Netinstall. I got this mesages using Netinstall:
Upgrade firmware options:
e - upgrade firmware over ethernet
s - upgrade firmware over serial port
your choice: e - upgrade firmware over ethernet
trying bootp protocol… OK
Got IP address: 10.100.0.25
resolved mac address 00:40:63:F1:EC:6A
transfer started … transfer ok, time=1.80s
your choice: s - upgrade firmware over serial port
xmodem receiver ready, waiting for data…
press +X several times to cancel transfer
press any key to continue…
file transfer ok
As you can see I ve tried to upgrade via Ethernet and via Serial (xmodem) and got the same.
In case of Ethernet, I receive the error, before I can see the Mikrotik in Netinstall, and select the image to load.
Any idea?
Looks like you are using the wrong package file…
RB411 is mipsbe
I realized that via serial I can upgrade de routerboard firmware, but not the RouterOs version. So that was a mistake from me.
The only problem now is that when I try to use Netinstall, the routerboard never appears in Netinstall, neither the installer in the routerboard (the one that waits for a RouterOS image to download). So I never reach to select any image.
Anyway the image I would try to download is “routeros-mipsbe-3.10.npk” (10.169.709 bytes)
I believe there should be instructions on MT’s site for using Netinstall. Otherwise search around on the forum.
Well, I ve read the Netinstall documentation and procedure (before my first post).
To see the difference I do a Netinstall upgrade to another Routerboard that was ok, and this is the log :
transfer started … transfer ok, time=1.49s
setting up elf image… OK
Welcome to MikroTik Router Software remote installation
Press Ctrl-Alt-Delete to abort
mac-address: 00:0C:42:1D:57:C9
mac-address: 00:0C:42:1D:57:CA
mac-address: 00:0C:42:1D:57:CB
software-id: YJMF-FTT key:
u8jHb/Ao1/NF6/T8rE9jzyEt5CDx+7jO0/W0Fp5wfiY/zVoa0rfGNoAFfnnRfsEDqPk/C0qWrbevIClhRwenmC==
Waiting for installation server…
After that, I saw the routerboard in the Netinstall window and do a succesful installation of routerOS package.
In the other hand, with the RB411 without kernel the log is (same PC running Netinstall and serial communication to RB, same cables, same power supply, etc) :
Press any key within 2 seconds to enter setup..
kernel not found
transfer started … transfer ok, time=1.83s
…and get there. It never appears in the Netinstall window.
Hello friends. I have same problem…
When i turn on the routerboard i can see it on hyperterminal, y press any key then it let me to access to the boot menu, then i set it to boot from ethernet, then it reboot and it got the ip from netinstall but it says “Transfer started…” and it just reboot and do nothing else than reboot and reboot without stop, so i can’t never see it on netinstall, never. so how can i install kernel if i can’t see it in netinstall? What can i do? please helpme i’m so frustrated. Thanks for replying and sorry for my bad english. Help Please.
