RB411 kernel panic - continously rebooting
One of my RB411 CPEs suddenly got problems, the board was endlessly caught in a reboot loop.
Replaced the CPE, brougth the funny RB to my desk and found that the following happens:
(some values like country and ssid are replaced by )
MikroTik 3.28
MikroTik Login: admin
Password:
  MMMM    MMMM       KKK                          TTTTTTTTTTT      KKK
  MMM MMMM MMM  III  KKK  KKK  RRRRRR     OOOOOO      TTT     III  KKK  KKK
  MMM  MM  MMM  III  KKKKK     RRR  RRR  OOO  OOO     TTT     III  KKKKK
  MMM      MMM  III  KKK KKK   RRRRRR    OOO  OOO     TTT     III  KKK KKK
  MMM      MMM  III  KKK  KKK  RRR  RRR   OOOOOO      TTT     III  KKK  KKK
  MikroTik RouterOS 3.28 (c) 1999-2009       http://www.mikrotik.com/
jan/02/1970 00:00:43 system,error,critical System rebooted because of kernel fail
ure
jan/02/1970 00:00:43 system,error,critical router rebooted without proper shutdow
n, probably power outage
[admin@MikroTik] > /interface wireless
[admin@MikroTik] /interface wireless> set 0 country=<country> disabled=no frequency-mode=\
\...     regulatory-domain radio-name=<radio-name> ssid=<ssid>              Oops[#1]:
Cpu 0
$ 0   : 00000000 1000d600 deadc0de 40000000
$ 4   : d0020000 000020d0 00009920 00002079
$ 8   : 00002127 00000000 c1efc60c c1efdbbc
$12   : 00000020 c1efc60c 00000001 c1fb59f2
$16   : c1efc184 c1efc164 c1fb5b9c c1efc60c
$20   : c1efc000 c1efdbbc 00000001 00000000
$24   : c1fb58f8 000186a0
$28   : c1fb4000 c1fb5b48 c1efdbbc c1fd641c
Hi    : 00000021
Lo    : 47af7400
epc   : c1fd65a0 a5212_hw_reset+0x40f4/0x6064 [a5212]
    Tainted: P
ra    : c1fd641c a5212_hw_reset+0x3f70/0x6064 [a5212]
Status: 1000d603    KERNEL EXL IE
Cause : 1080001c
PrId  : 00019374 (MIPS 24K)
Process wireless (pid: 851, threadinfo=c1fb4000, task=c1c1de68, tls=00000000)
Stack : c1efc000 0000001a 00000024 0000a300 c1fb5b74 c1fb5b74 0000000a ffffffff
        00000000 001a0000 00245d80 00030001 00000008 00010002 00010024 00240022
        0020001c 00000000 00000000 00000000 00000000 00260026 00260026 00260026
        00260026 00260026 00260026 00260026 00260026 00010002 00020001 157c1644
        167116c1 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Call Trace:
[<c1fd65a0>] a5212_hw_reset+0x40f4/0x6064 [a5212]
[<c1fc2c50>] a5212_interrupt+0xdb8/0x1ff8 [a5212]
Code: 00861021  8c420000  3c034000 <00431024> 10400128  3405990c  00852021  8c830000  3c0200ff
---[ end trace 358912579604495c ]---
Kernel panic - not syncing: Fatal exception in interrupt
panicSaver: dumping panic to flash
flash: erase f
flash: prg f
spi_program_sector 0000000f
Rebooting in 1 seconds..
RouterBOOT booter 2.20
RouterBoard 411
CPU frequency: 100 MHz
  Memory size:  32 MB
Press any key within 5 seconds to enter setup.....
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
Starting...
Starting services...
MikroTik 3.28
Password:
Re-installed 3.28 and reset config using netinstall, and upgraded FW to latest version (2.20)
I can log in to the router from the console and move around, but ss can be seen, as soon as I try to paste a config to the console, the board performs a memory dump and reboots once again.
Is the RB ready for the thrashcan, or is there still hope?
It seems something wrong with mPCI. Replace wireless card and try again.
That’s what friends are for!
A new MiniPCI and off we went.
Thanks a lot aaa!
