RB411 + minipci wifi adapter = need help to config. iproutes
Hello, my boss have just buyd Mikrotik RB411 with wifi minipci card. And of course i must config all this thing - but never done smth like his before.
Checked many forums and posts about my problem but found nothing usefull. Maybe someone can give me a little tutorial? :blush:
Ok i have chosen the ip for Ether1 interface - 192.168.1.0 / 24, which ip better to choose for Wlan1 interface? and how to configure route ip ?
(i just need the wifi antenna to scan for open wifi APs and connect to different APs if they are open (this will be done through winbox))
thank you for your help :slight_smile:
Put the wireless interface in station pseudobridge, bridge the ports together, and connect at will. You may want to enable DHCP on the wireless interface, so when you connect to the other APs you get an IP from there. Assign your own IP to the eth interface so you can connect to it with wimbox. then there is no configuration of the routes, it is done automatically.
