Hi there, I want to reinstall my routerboard RB411 with netinstall using the reset button/hole procedure and it doesn’t work.
My RB411 is stucked since I’ve tried upgrading it to a newer version, I’ve just uploaded a .npk file to the RB and hit the reboot buton in the winbox and it doesn’t work since that.
I’ve tried reseting the RB.
I’ve tried booting up with the reset hole contact to boot in Netinstall but the software doesn’t “see” the RB.
Windows 7X64
Firewall off.
Antivirus off.
Others pc interface wlan,virtualbox disabled.
Dhcp manually assigned 192.168.88.2
Bootserver enabled on IP 192.168.88.1
I can’t figure it out, help me!!!
