I RB411 with AR5211A
the router restarts when enable card
routeros tested
3.3 3.6 3.7 3.8 3.9
bios 2.13 2.14
tested five RB411
with RB133 and RB133c works well
thanks
routeros tested
3.3 3.6 3.7 3.8 3.9
bios 2.13 2.14
tested five RB411
thanks
Power supply is not strong enough.
i have tested dc 19v 4,7A the router restarts when enable card
RB133 works well dc 18v 0.8A
tested 5 minipci 5 RB411
enable card and restart system
According to the manual
http://www.routerboard.com/pdf/rb411ugA.pdf
NOTE: that RB411 currently does not support Senao 8602 cards, Atheros
AR5211 or older chipset and Prism chipset based cards.
There was a thread where someone was using an older card and it was rebooting on them.
-Louis
Used 8602 (AR5312), 3601/3602 (AR5212) without any problem.
Is it true 411 doesnt support older chipsets? I don’t see that written in the user guide.
nmp-8602 is ok for me…
but board is very hot, no heatsink attached
