i have a access to a very weak open wifi signal on good days, on bad days the signal is just out of reach.
i have a spare RB411 + r52 + antena
i want to connect my laptop to the RB411 via ethernet cable and then use the RB411 + Radio to pick up the weak signal
would i configure the RB411 as an access point, a station, a WDS, a Bridge??
sorry, very new at all this,
and is there a wiki somewhere that can show me how to do the chosen setup?
thanks
Piet Bez
OK, i have done as the example in the wiki, but still no connection.
the wifi signal is unprotected, i can pick it up with my laptop without any password. but cant pick it up if i connect via the RB411.
here is a screen cap of my winbox setup.
what you need is to use station pseudobridge,
then add a bridge between ether1 and wlan1 and you are done..
802.11 doesnt allow to bridge on the station side..
this is like a bridge but, no matter what you connect on your ether1 side the AP will see only 1 mac address, the wlan1 one.
Regards!
