RB411 tx problem
Hi all.
Lately, we have noticed a serious issue with multiple RB411(s) being used as client in station mode - Have not tested in other modes yet.
Tx-power=default.
All seems fine, the RB411(s) associate with the tower APs and tx/rx CCQs are fine and all’s well.
Enter clients further than 15kms. The clients can browse and download without hassle, ie small DNS request and http transmissions.
Signals are gr8 and not a single disconnection, until a larger transmission, such as sending mail or uploading a file is initiated. The tx-ccq instantaneously proceeds with a gradual drop from say 75% to 0% and then the RB411 station disassociates from the AP. The radio stops all communication for a random period of a few minutes though the RB is still up and running. No reboots.
Suspecting the mini-pci, we replace it with different brands with different tx powers and all give the same results.
Then suspecting a long PoE CATV, we connect the power using the jack socket and with the power adapter at normal cable length. The radios stop the disassociations, but still proceed into a declining tx-ccq to around 10-20% and stop all communication while the RB is still up and running. No reboots.
This happens not only on one but all latest RB411s. It seems, once the distance is quite long, the mini-pci requests to raise the default tx-power and that is causes it to die for a while most probably by insufficient current delivered by the RB411 mini-pci controller or something.
Simply, the RB411 is not able to provide power for larger transmissions - as simple as sending a short text email. The fastest killer is bandwidth-test; hardly operates for a second then the radio is dead for a short while and then comes back to life, though the RB411 does not reboot during the whole process. So our guess is that this is a problem on the RB411 and not the power source. All mini-pci cards used for testing run smoothly on other boards.
No Compression is enabled. Situation persists connecting to different APs.
Any advice Appreciated, else RMA and another bad batch to deal with! Or, back to RB133c and RB411s simply suck!
PS: there is a post somewhere of how to increase the RB wattage handling capability through some firmware setting or upgrade. Don’t seem to find it, so kindly, can anyone help with the command or setting? Thx
Ok tested today on shorter distance, same crap.
what wireless card you are using?
Maybe you have some interference in that channel?
Thx for response.
RB52, RB52H, Compex, SR2… you name it. tested almost all available. same result.
Tested brand new out of the box RB411s, same results.
Power supplies: Tested 18volt and 24volt. 48volt obviously does not work - Overvoltage protection.
it is a point-to-point link?
have you tried to use different channel? It is 5ghz or 2.4ghz?
Other boards runs ok?
You can make the support output file when you have these problems and send it to support@mikrotik.com
activate nstreme
It’s in station mode, haven’t tried AP-Bridge yet.
Yes different channels, different High-Sites.
wondering, is it possible the RB is causing noise onto the mini-pci?
Using PoE causes disconnection during tx: Tx-CCQ gradual drop then disconnection.
Using Jack causes no communication without disconnection: Tx-CCQ gradual drop until no communication then disconnection.
Will send suppout.
Thx again.
Got it!
Reduced Firmware to 2.13 and it solved the problem! yet not completely! Still tx-ccq drops! But at least it keeps connected!
Firmware Issue it seems or what?
what firmware version you had before downgrading?
2.15 then 2.16
Dunno how then it went to 2.17
but finally 2.13
Though still do get timeouts and occasional disconnection. Can’t really transmit much traffic!
Use hw-retries=15 and what mhz channel size you using. How many customers?
Thx for the effort.
The problem resides on the client CPEs in station mode. Though, we have not tested a RB411 in AP mode.
Yes do this on ap and client. It effects both directions.
Thx for your interest Dallas.
Upgraded the client unit to ROS ver3.15 and Bootloader 2.18, still same issue. Once the unit tries to transmit heavily, the tx-ccq drops and the unit disconnects from the AP.
You can call me and I will control it and tell you what I think if you want. Or maybe even fix it.
Dallas
