ROS 5.7 RB411 vs RB411 (both XR5 card) after upgrade to 5.7, distance disappeared. Box is empy. Any ideas? Thanks
I have a problem looks like to you. after upgrade RB433 with two XR5 cards to V5.5, The wireless cards gone !!!
Then I have to downgrade to V4.17. I think it may caused by drivers incompatibility.
You have XR5 in RB433?..always when I tried run XR5 on RB433 it still reboot around (after “enable” radio on default TX). I thought that XR5 is not compatible with RB433…in RB411 XR5 works perfecly!
Yeah but I forgot to add AH to the end
. Mine is RB433AH with two XR5 card and works fine in v 4.17
I have three of them, One for Access Point and the next two, created a wireless bridge with 5km distance. I used two Kenbotong dual pol 32 dBi. The result was great. 80 Mbps real throughput. I use nstream dual salve mode.
dont try to upgrade on 5.x, My 433AH works with XR5 only with 0db manual TX. With default it was still rebooting around.
