With routeros 3.3 my signal is rx -65 tx -64. When I install 3.10 or 3.11 my signal is -89 both ways. Why is the router os having a issue?
Dallas
Dallas
Make sure you have the correct antenna selected. There is antenna a and antenna b. This can vary with different cards; one is the main connector and the other would be the auxiliary connector.
I didnt change hardware and changed firmware to 3.3 and all worked awesome.
Dallas
What I’m referring to is a configuration option..
Ok, I am confused. I dont understand, when I had the firmware at 3.3 the signal was awesome. That would mean its hooked up correctly right? I am soon going to goto the customers house and replace the whole radio. See what happens.
dallas
