I recently bought the RouterBoard RB411 and plan to use it with XR9.At first turn on,the B411 is working well(power LED lights up).After the second beep sound the ethernet(RJ45) is disconnected.Was it because of the card not compatible or got some power issue?
One more thing,what is actually the default ip address for accessing the RB411 card?can it be define by just connecting the RJ45 cable on PC or need DB9 connection?
Thanks…
Attached is the XR9 datasheet
XR9_2.pdf (61.3 KB)
