RB411AH 100% CPU Load
Hi Guys
I have a RB411AH with OS 5.0rc1 and the CPU sits on 100% untill it is rebooted.
Tools/Profile shows that the routing is using most of the CPU.
I am using OSPF.
Has anyone else had this issue and what did they do to fix the problem.
Cheers
routing locked up, this problem will be fixed in rc2
