RB411AH - Lose link when btest in TCP
Hi!
It’s first time I have this problem. I mounted a nstreme and bonded link with 2x rb411AH and 2x UB5 minipci, as usually. I’m using 4.17 ROS version there.
I make a btest in UDP, and the CPU goes to 35-50% and I get 80 Mbps more or less. 100/100 CCQ and signal is -50/-52
I make a btest in TCP, setting the max speed to “55M” in btest, and I get 45 Mbps, 100 CCQ and signal ok. 100% of CPU (it’s ok with this test..)
I make a btest in TCP with no limit in Speed and the CPU goes to 100% (ok) but the link is going slow slow slow and then die. Extensive data loss.. xDD why?!
If I don’t touck the link and I work normally, all is OK, but with Btest in TCP without a speed limit.. the link fails.
Very strange. Anyone has 4.17 in a link with 411AH or 433AH and can test this test?
Thanks!
