RB411AR, R52nM and RF Elements Station Box S
I have a RB411AR working in an RF elements station box S with a single 5dbi N type antenna.
I use this as an access point. I intend to install an R52nM and change the antenna to a dual pol sector.
First question:- Can the R52nM be configured as an AP?
Second question:- Has anyone tried to fit an R52nM plus Rb411AR into an Rf Elements station box?
I do not think that the R52nM will fit if you are using N type pigtails (the conector gets in the way of the mini PCI board)
But I think it may if you use sma pigtails (which I intend to do). Also I think it depends if the R52nM is a 111A or 111B board
the 111B board is shorter.
Regards
