RB411GL as AP and NanoStationM5 for peers MIMO ??
Is it possible to connect Mikrotik MIMO technology and Ubiquity technology in p2mp network ??
For example: if I use RB411 and r52hn card and dualpole sector for 802.11n and wanna connect NanostationM5s as clients?
Thank You
Only if you dont use NV2
It will work on MIMO standard ? Thank you
And what about if I want to connect STX to the ubiquity rocketM5 airmax standard?
Thank you
14.3.2013.
ap-ROCKETm5 Airmax disabled
client STX
40MHz channel width
Speed on btest 96.4Mbps
zer gut :slight_smile:
