RB411GL can't connect.
When I configure bridge from webpage for RB411 board,it resets without notice. I guess I change some items to make it effect, so the board automatically resets. But after taht I can’t connect the board any more with default IP 192.168.88.1(I didn’t change it). I tried long press the reset button to set factory default, or powerup while long pressing button, it donesn’t work. I even don’t see the board reset.
There is only usb port on the board. How can connect it and set the default so that I can connect it through 192.168.88.1?
Thanks.
You need to netinstall
