RB411R loose the wlan inetrface
Hello, sometimes it loose the wlan interface, after several hard reset come back. Working unintelligible period, and can be loose again.
How it fix?
I have the same problem happened to me r52h XR5, with RB411.
Check your wireless under system packages.
I’ve had a few boards that lost the wireless package.
Reinstall or downgrade took care of it in my case.
