I am trying to get that modem working on my board, but I can not get the modem to respond on the terminal.
The device is present
[admin@TEST_1] > /system resource usb print
# DEVICE VENDOR NAME SPEED
0 2:1 RB400 EHCI 480 Mbps
1 2:3 HUAWEI Technology HUAWEI Mobile 480 Mbps
2 1:1 RB400 OHCI 12 Mbps
[admin@TEST_1] >[/code
but when I set baud to 9600 (as most USB modems use that speed) and try to get the answer on the terminal i see nothing:
[code][admin@TEST_1] > /port print
Flags: I - inactive
# NAME CHANNELS USED-BY BAUD-RATE
0 serial0 1 Serial Console auto
1 usb2 2 9600
[admin@TEST_1] > /port set usb2 baud-rate=9600
Flags: I - inactive
1 usb2 2 9600
[admin@TEST_1] > /system serial-terminal usb2 channel=2
failure: no such channel
[admin@TEST_1] > /system serial-terminal usb2 channel=1
[Ctrl-A is the prefix key]
Any ideas?
In the IP config and all of the others I see ether1, wlan and ppp-out1 and ppp-out2, so it seems the modem is present in the system.
I have seen some people like Pilgrim made that config run. I hope you could help me to run it as well.
