RB411U + MC8790 success connection but no internet -SOLVED
Hi everybody;
I can connect to 3G network as below after this what will I do for internet connection via ethernet port or wlan ( I have wireless card).
Could you explain other IP defination, NAT etc?
regards.
[admin@RB411U] > /port print
Flags: I - inactive
 #   NAME                      CHANNELS   USED-BY                     BAUD-RATE
 0   serial0                   1          Serial Console              auto
 1   usb2                      7          PPP <ppp-out1>              9600
[admin@RB411U] > /system resource usb print
 # DEVICE VENDOR                   NAME                  SPEED
 0 2:1                             RB400 EHCI            480 Mbps
 1 2:2    Sierra Wireless, Inco... MC8790                480 Mbps
 2 1:1                             RB400 OHCI            12 Mbps
[admin@RB411U] > /interface ppp-client
[admin@RB411U] /interface ppp-client> print
 0  R name="ppp-out1" max-mtu=1500 max-mru=1500 mrru=disabled port=usb2
      data-channel=3 info-channel=0 apn="internet" pin="" user="" password=""
      profile=default phone="*99#" dial-command="ATDT"
      modem-init="AT+CGDCONT=1" null-modem=no dial-on-demand=no
      add-default-route=yes use-peer-dns=yes allow=pap,chap,mschap1,mschap2
[admin@RB411U] /interface ppp-client> ..
[admin@RB411U] /interface> ..
[admin@RB411U] > /ip route print
 0  DS  0.0.0.0/0                          81.6.72.198        1
 1 ADC  81.6.72.198/32     81.6.72.198     ppp-out1           0
 2 ADC  192.168.2.0/24     192.168.2.1     ether1             0
 3 ADC  192.168.10.0/24    192.168.10.1    wlan1              0
[admin@RB411U] > /interface ppp-client log print
bad command name log (line 1 column 23)
[admin@RB411U] /interface ppp-client> log print
bad command name log (line 1 column 1)
[admin@RB411U] /interface ppp-client> /log print
02:00:21 system,info router rebooted
02:00:29 async,ppp,info ppp-out1: initializing...
02:00:29 async,ppp,info ppp-out1: reseting link...
02:00:29 async,ppp,info ppp-out1: reseting link... - could not acquire serial po
rt
02:00:30 async,ppp,info ppp-out1: disconnected
02:00:30 async,ppp,info ppp-out1: initializing...
02:00:30 async,ppp,info ppp-out1: reseting link...
02:00:31 async,ppp,info ppp-out1: initializing modem...
02:00:31 async,ppp,info ppp-out1: dialing out...
02:00:31 async,ppp,info ppp-out1: authenticated
02:00:36 async,ppp,info ppp-out1: connected
hi,
NAT masquerade.
Hi;
is there any wiki example page ?
regards.
slightly different, but explains the nat setup.
rosmE.pdf (448 KB)
or this
http://wiki.mikrotik.com/wiki/How_to_Connect_your_Home_Network_to_xDSL_Line
Hi;
no internet on LAN (local), where is my mistake?
I could not find my mistake.
regars.
04:21:46 async,ppp,info 3G: initializing...
04:21:46 async,ppp,info 3G: reseting link...
04:21:46 system,info device changed by admin
04:21:47 async,ppp,info 3G: terminating... - modem hunged up
04:21:47 async,ppp,info 3G: disconnected
04:21:47 async,ppp,info 3G: initializing...
04:21:47 async,ppp,info 3G: reseting link...
04:21:48 async,ppp,info 3G: initializing modem...
04:21:48 async,ppp,info 3G: dialing out...
04:21:48 async,ppp,info 3G: authenticated
04:21:51 async,ppp,info 3G: connected
[admin@RB411U] > ip address print
 #   ADDRESS            NETWORK         BROADCAST       INTERFACE
 0   ;;; LOCAL IP
     192.168.0.1/24     192.168.0.0     192.168.2.255   LAN
 1   192.168.10.1/24    192.168.10.0    192.168.10.255  WLAN
 2 D 81.6.124.185/32    81.6.124.185    0.0.0.0         3G
 3   10.0.0.217/32      10.0.0.217      10.0.0.217      3G
[admin@RB411U] > ip route print
 0  DS  0.0.0.0/0                          81.6.124.185       1
 1 ADC  10.0.0.217/32      10.0.0.217      3G                 0
 2 ADC  81.6.124.185/32    81.6.124.185    3G                 0
 3 ADC  192.168.0.0/24     192.168.0.1     LAN                0
 4 ADC  192.168.10.0/24    192.168.10.1    WLAN               0
[admin@RB411U] > ip firewall nat print
 0   chain=srcnat action=masquerade out-interface=3G
[admin@RB411U] >
Can anybody help me?
I tried NAT but I couldn’t reach internet by router.
thanks.
The problem is with route,
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
Default gateway is without 'A' sign (active), so it is not working.
I do not know why A is missing, as in your setup it should be with A. You may try to set add-default-gateway=no and add it manually to check if the internet works.
Let us know about the result.
Sergejs;
Thank you for answer;
I will try your advise and I will be inform you.
I have also similar topic in “RouterOS Community Support [General]”.
and I think problem is below; my gateway and dst Ip is same that is comming from 3G provider.
I can not change this. Because that is 3G provider rule and they are giving same IP as dst IP and Gateway IP.
[admin@MikroTik] > ip route pr
0  DS  0.0.0.0/0                          188.38.52.220      1
1 ADC  188.38.52.220/32   188.38.52.220   ppp-out1           0
2 ADC  192.168.1.0/24     192.168.1.1     ether1             0
Yes, I see that it is from your provider.
As I told you try with static gateway rule.
Make sure the latest MikroTik RouterOS version is installed on the router.
Contact your provider to clarify, whether they haver proper configuration on PPP server on their side.
Sergejs hi;
thanks for your advice
Problem solved, I can connect 3G network and I can surf Internet via RB411U+MC8790 combination.
Problem was add-default-route=yes, don’t enable that in UMTS interface and add manualy route with gatewat=ppp interface as UMTS connection.
Can you clarify what you added as a route??
This would help me heaps..
hello ta2mzl
can you please explain how did you add the static route…coz i’m facing the same problem since last few days.
thanks
hi adnan ;
where are u from?
