Hi!
I have a problem with RB411U + Sierra Wireless MC8795V or MC8790.
The routerOS v5.0beta6 is not able to set SIM PIN.
PIN Status: waiting for primary PIN
I must type it manually in :
/system serial-terminal usb3 channel=3
at+cpin=XXXX
Ctrl-A + Q
Then modem connected OK. Or I must use sim card without PIN lock.
Modem Revision: K2_0_7_19AP C:/WS/FW/K2_0_7_19AP/MSM6290/SRC 2009/10/26 17:26:12
Previous version of routerboard OS the same problem.
The modem MC8781 works fine.
I try modem init: at+cpin=1111 and at+cfun=1, but not successfull.
How will be look script to put AT commands in /system serial-terminal usb3 channel=3 ?
What can I do for automaticlly start up GSM connection on card with PIN lock?
Thanks for replay.
Best Regards
Bartekj
There is my config info:
[admin@KPP] > /interface ppp-client info 0
status: “ready”
pin-status: “waiting for primary PIN”
functionality: “full”
gprs-class: “ERROR”
manufacturer: “Sierra Wireless, Incorporated”
model: “MC8795V”
revision: “K2_0_7_19AP C:/WS/FW/K2_0_7_19AP/MSM6290/SRC 2009/10/26 17:26:12”
serial-number: “355310030069037”
current-operator: “Limited Service”
access-technology: “GSM compact”
signal-strengh: 0
frame-error-rate: “”
[admin@KPP] > /interface ppp-client print
0 ;;; Public APN
name=“ppp-out2” max-mtu=1500 max-mru=1500 mrru=disabled port=usb3 data-channel=6 info-channel=3 apn=“internet”
pin=“1111” user=“” password=“” profile=default phone=“” dial-command=“ATDT” modem-init=“” null-modem=no
dial-on-demand=no add-default-route=yes use-peer-dns=yes keepalive-timeout=30 allow=pap,chap,mschap1,mschap2
