RB411U / problem to connecting a USB Modem
Using the two examples on the wiki as guideline I am trying to use my RB411U and a Huawei 159 to make a AP / Internet connection.
Disabling serial0 I am able to get around the initial "port already in use" problem when executing "/system serial-terminal usb2 channel=0" command. I have set up the PPP interface using port USB2. In the log I can see that the process stalls by when trying to initialize the modem.
Disabling the ppp interface and using /system serial-terminal usb2 channel=0 I am also not able to get any response from the modem.
When using the modem directly on the PC it works fine. The sim card requires a pin. Could that be the problem? Or what could be the reason that I do not get any response from the modem?
Best regards, Pilgrim
[admin@MikroTik] > port pr
Flags: I - inactive
NAME CHANNELS USED-BY BAUD-RATE
0 serial0 1 auto
1 usb2 2 9600
[admin@MikroTik] > system resource usb print
DEVICE VENDOR NAME SPEED
0 2:1 RB400 EHCI 480 Mbps
1 2:4 HUAWEI Technology HUAWEI Mobile 480 Mbps
2 1:1 RB400 OHCI 12 Mbps
[admin@MikroTik] > /system serial-terminal usb2 channel=0
[Ctrl-A is the prefix key]
[Q - quit connection] [A - send Ctrl-A prefix] [R - autoconfigure rate]
Welcome back!
[admin@MikroTik] >
Try to use different channel
I am now connected throught the RB411U :slight_smile: works like a charm now. Seems that the problem was the sim pin lock. That apparently made the moden not repsond. Once disabled everthing everything started working.
rgs Pilgrim
