RB411U Using USB Modem doesn't browse after Power Failure
My RB411U stops browsing whenever it reboots due to power failure. the PPP refuses to connect. Am I the only one expeirencing this? and my time keeps resetting. is ther any thing i can do to automatically correct it? Anyone suggestions
could you check http://forum.mikrotik.com/t/vodafone-k3765-huawei-usb-with-433uah/36861/1 this topic if your problem is similar to my ?
Yes it is… have u had any solutions?
my only available solution is to create a schedule to reboot the computer every 2 hours because when the computer is rebooted via winbox it connects to the internet. but i want a stable solution. for multiple deployment
I try to ask two times here, but till now no reply. For me sometimes did not help rebooting, only plug out and back plug in the modem. I am looking for stable solution too - I have IP cameras on the roads with only power cable and I need to solve connection for the internet - 3G is the best but when this problem appears once per week, somewho must to go to the site, open the box etc. Has anyone solved 3G without problems ?
email support a supout.rif file that you make when modem doesn’t work (after this power failure)
