RB411UAHR + GOBI2000
Hi!
I have problem to launch 3G modem, Qualcomm 3G in Gobi2000 RB411UAHR. Does anyone have any experience with this hardware? I have read many guides, so far without success.
Thanks.
look int othis topic, it might help:
http://forum.mikrotik.com/t/anyone-experimented-with-the-new-qualcomm-gobi-wwan/40783/1
Thank you for your advice. That link is a RB411U, but I RB411UAHR where it does not work. Hence the new topic.
the same card works in RB411U but doesn’t in RB411UAHR?
Do you see that card in the system resource USB?
Yes.
The USB Device is reported as 2:2
Vendor Qualcomm Incorporated
Name Qualcomm Gobi 2000
Serial Number -
Speed ​​480Mbps
MT v5.0rc7
Driver Files in the directory and the directory is set port/firmware
upgrade to the latest RouterOS v5.0rc and send the support to support@mikrotik.com
also send the support output file when the card is located in the RB411U.
Hi.
I can give RB a public IP to access.
Access data can send the mail.
Thanks.
contact support@mikrotik.com about this issue.
