RB433 "Cannot allocate memory"
On the RB433 was this problem:
RouterBOOT booter 2.15
RouterBoard 433
CPU frequency: 300 MHz
  Memory size:  64 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
init started
Starting...
/etc/rc.d/rc.sysinit: 21: cannot create /var/run/utmp: Cannot allocate memory
System halted.
The problem has become suddenly. There was no power failure, because the router was connected to a UPS. Mikrotik version was 3.25.
Someone knows what could be causing this?
Router is installed away from the office so I would like to avoid such surprises in the future.
Try to run memtest.
I did a memtest and nothing showed. I installed ROS 3.27 with NetInstall (it wasn’t 3.28 yet) and for now it works.
