RB433 firewall setting
I have RB433 with wireless mini pci, wirless mode=[station wds]. everything is working perfectly but I want to activate some firewall rules to block websites
for example to block facebook:
I did :
firewall filter chain: Forward Protocol : TCP Port:80 Content :www.facebook.com
BUT it is not working
still having the ability to access the website
looks like that rules are not activated or there is no firewall at all
and the requested URL are not passing through the rule
what did I miss?
Best regards
Did you try going to https facebook which your rule would not have worked for. Also, what is the config of your router. If you have ethernet interfaces bridged with your wlan then you will more than likely need to turn on “Use IP Firewall” in your bridge settings.
/interface bridge settings set use-ip-firewall=yes
But that is also not a good way to block facebook. Using Layer 7 you will get a bunch of false positives and block any website with even a facebook link on it. It is better to do something like this.
add action=drop chain=forward comment="Block Facebook" dst-address=173.252.64.0/18
add action=drop chain=forward comment="Block Facebook" dst-address=204.15.20.0/22
add action=drop chain=forward comment="Block Facebook" dst-address=66.220.144.0/20
add action=drop chain=forward comment="Block Facebook" dst-address=31.13.64.0/18
add action=drop chain=forward comment="Block Facebook" dst-address=31.13.24.0/21
add action=drop chain=forward comment="Block Facebook" dst-address=69.171.224.0/19
add action=drop chain=forward comment="Block Facebook" dst-address=74.119.76.0/22
add action=drop chain=forward comment="Block Facebook" dst-address=103.4.96.0/22
Thank you very much for your help. but still not working. do i have to try another thing? thanks again
hi thanks for the help but still not working. any thing new?
