Hi, I am running RB433 on v5.9. Flash is at 100%.
Free disk space is a 0%.
HW reset not working.
Cannot clear or rebuild userman.
Do I need to buy a new RB433 or is there any other solution?
Kind regards,
Andre Druyts
Kind regards,
Andre Druyts
Reinstall with Netinstall to clear it. User manager is not really suited for small storage disks, you need to use it somewhere with ample available disk space.
Thanks, it worked.
I disabled usermanager package and deleted it on storage then enabled usermanager again and reloaded everything.
No need to buy new RB433. ![]()
Kind regards,
Andre
