RB433 (IC Plus 175C chip) - VLAN on eth1 not working
I have an (aged) RB433 and would like to utilize VLAN on eth1.
The goal is to have 2 VAPs bridged to two VLANs on eth1.
The switch chip (IC Plus 175C) which controls eth2 and eth3 does not support VLANs.
[admin@MikroTik] > interface print
 #     NAME                                TYPE         MTU L2MTU  MAX-L2MTU
 0  R  ether1                              ether       1500  1526
 1  R  ether2                              ether       1500  1522       1522
 2     ether3                              ether       1500  1522       1522
 3   S wifiDMZ                             wlan        1500  2290
 4     wifiMasterAP                        wlan        1500  2290
 5   S wifiPC                              wlan        1500  2290
 6  R  brDMZ                               bridge      1500  1522
 7  R  brManagement                        bridge      1500  1522
 8  R  brPCs                               bridge      1500  1522
 9  RS vlDMZ                               vlan        1500  1522
10  RS vlMgmt                              vlan        1500  1522
11  RS vlPC                                vlan        1500  1522
[admin@MikroTik] > /ip dhcp-client print
 #   INTERFACE           USE ADD-DEFAULT-ROUTE STATUS        ADDRESS
 0   vlMgmt              no  no                searching...
 1   ether2              yes yes               bound         192.168.121.6/24
 2   brDMZ               no  no                searching...
 3   ether1              no  no                searching...
 4   vlPC                yes no                searching...
[admin@MikroTik] > /interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic
 #    INTERFACE              BRIDGE              PRIORITY  PATH-COST    HORIZON
 0 I  wifiDMZ                brDMZ                   0x80         10       none
 1 I  wifiPC                 brPCs                   0x80         10       none
 2    vlMgmt                 brManagement            0x80         10       none
 3    vlPC                   brPCs                   0x80         10       none
 4    vlDMZ                  brDMZ                   0x80         10       none
The attached switch (AT x610) is configured okay and works with that very same VLAN configuration on other ports.
Traffic indicates that packets are sent (Tx) but none are received (Rx).
Does anyone have an idea of how to approach this, please?
Cheers,
Stefan
Is Ether1 a port member of a bridge?
no, ether1 is not a bridge member. Should it be?
Try posting the config (output from /export compact) so we can see what is going on.
The switch configuration. Native VLAN should allow the “native VLAN” to obtain and IP address from the DHCP server listening in VLAN 2000
sw-core-01#show running-config interface port1.0.19
 description "trunk to wifi unit"
 switchport
 switchport mode trunk
 switchport trunk allowed vlan add 2001,2006,2100
 switchport trunk native vlan 2000
sw-core-01#show vlan all
VLAN ID  Name            Type    State   Member ports
                                         (u)-Untagged, (t)-Tagged
1       default          STATIC  ACTIVE  po1(t) port1.0.1(u) port1.0.3(u)
                                         port1.0.23(t) port1.0.24(t)
1000    sq-vlServers     STATIC  ACTIVE  po1(t) port1.0.21(t) port1.0.22(t)
1006    sq-vlDMZ         STATIC  ACTIVE  po1(t) port1.0.3(t) port1.0.21(t)
                                         port1.0.22(t) port1.0.23(t)
                                         port1.0.24(t)
2000    se-vlServers     STATIC  ACTIVE  po1(t) port1.0.1(t) port1.0.4(u)
                                         port1.0.5(u) port1.0.6(u) port1.0.7(u)
                                         port1.0.8(u) port1.0.9(u)
                                         port1.0.10(u) port1.0.11(u)
                                         port1.0.12(u) port1.0.13(u)
                                         port1.0.19(u) port1.0.23(t)
                                         port1.0.24(t)
2001    se-vlMgmt        STATIC  ACTIVE  po1(t) port1.0.2(u) port1.0.19(t)
2002    se-vlPhotography STATIC  ACTIVE  po1(t) port1.0.23(t) port1.0.24(t)
2003    se-vlCCTV        STATIC  ACTIVE  po1(t) port1.0.23(t) port1.0.24(t)
2004    se-vlRobots      STATIC  ACTIVE  po1(t) port1.0.23(t) port1.0.24(t)
2005    se-vlTelephony   STATIC  ACTIVE  po1(t) port1.0.23(t) port1.0.24(t)
2006    se-vlDMZ         STATIC  ACTIVE  po1(t) port1.0.3(t) port1.0.19(t)
                                         port1.0.21(t) port1.0.23(t)
                                         port1.0.24(t)
2100    se-vlPCs         STATIC  ACTIVE  po1(t) port1.0.14(u) port1.0.15(u)
                                         port1.0.16(u) port1.0.17(u)
                                         port1.0.18(u) port1.0.19(t)
                                         port1.0.20(u) port1.0.23(t)
                                         port1.0.24(t)
sw-core-01#
the exported MT configuration
[admin@MikroTik] > /export compact
# jan/05/1970 16:19:20 by RouterOS 6.19
# software id = XH4Y-GCBY
add l2mtu=1522 name=brDMZ
add l2mtu=1522 name=brManagement
add l2mtu=1522 name=brPCs
set [ find default-name=ether1 ] auto-negotiation=no
/interface vlan
add interface=ether1 l2mtu=1522 name=vlDMZ vlan-id=2006
add interface=ether1 l2mtu=1522 name=vlMgmt vlan-id=2001
add interface=ether1 l2mtu=1522 name=vlPC vlan-id=2100
add authentication-types=wpa-psk,wpa2-psk eap-methods="" \
    management-protection=allowed mode=dynamic-keys name=profileWifiBusiness \
    supplicant-identity="" wpa-pre-shared-key=somethingnot2easy% \
    wpa2-pre-shared-key=somethingnot2easy%
    management-protection=allowed mode=dynamic-keys name=profileWifiDMZ \
    supplicant-identity="" wpa-pre-shared-key=whateverthatpskis \
    wpa2-pre-shared-key=whateverthatpskis
add authentication-types=wpa2-psk eap-methods="" management-protection=\
    allowed mode=dynamic-keys name=profileMasterAP supplicant-identity="" \
    wpa2-pre-shared-key="sdgf53#\$hfhdfgryh545SRfdg\$218&^%"
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g country="new zealand" disabled=\
    no frequency=auto hide-ssid=yes l2mtu=2290 mode=ap-bridge name=\
    wifiMasterAP security-profile=profileMasterAP ssid="v-C}2#TMKwh2B@7<" \
    tx-power=30 tx-power-mode=all-rates-fixed
add disabled=no l2mtu=2290 mac-address=02:02:6F:48:DE:14 master-interface=\
    wifiMasterAP name=wifiPC ssid="Skyline Business" wds-cost-range=0 \
    wds-default-cost=0
add disabled=no l2mtu=2290 mac-address=02:02:6F:48:DE:13 master-interface=\
    wifiMasterAP name=wifiDMZ ssid="Skyline Enterprises" wds-cost-range=0 \
    wds-default-bridge=brDMZ wds-default-cost=0
/port
set 0 name=serial0
add bridge=brDMZ interface=wifiDMZ
add bridge=brPCs interface=wifiPC
add bridge=brManagement interface=vlMgmt
add bridge=brPCs interface=vlPC
add bridge=brDMZ interface=vlDMZ
add address=192.168.88.1/24 comment="default configuration" interface=ether1 \
    network=192.168.88.0
add address=192.168.120.66/26 interface=vlMgmt network=192.168.120.64
/ip dhcp-client
add add-default-route=no dhcp-options=hostname,clientid disabled=no \
    interface=vlMgmt use-peer-dns=no use-peer-ntp=no
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no \
    interface=ether2
    interface=brDMZ use-peer-dns=no use-peer-ntp=no
    interface=ether1 use-peer-dns=no use-peer-ntp=no
    interface=vlPC
/ip upnp
set allow-disable-external-interface=no
/tool sniffer
set filter-interface=ether1
[admin@MikroTik] >
from the switch’s perspective the MAC of the routerboard is visible (per VLAN) but communication never makes it to layer 3 leaving the arp table empty.
sw-core-01>show mac address-table | include port1.0.19
2000 port1.0.19   000c.4229.eef2   forward   dynamic
2001 port1.0.19   000c.4229.eef2   forward   dynamic
2006 port1.0.19   000c.4229.eef2   forward   dynamic
2100 port1.0.19   000c.4229.eef2   forward   dynamic
sw-core-01>ping 192.168.120.66
PING 192.168.120.66 (192.168.120.66) 56(84) bytes of data.
From 192.168.120.126 icmp_seq=2 Destination Host Unreachable
From 192.168.120.126 icmp_seq=3 Destination Host Unreachable
From 192.168.120.126 icmp_seq=4 Destination Host Unreachable
From 192.168.120.126 icmp_seq=5 Destination Host Unreachable
--- 192.168.120.66 ping statistics ---
5 packets transmitted, 0 received, +4 errors, 100% packet loss, time 4000ms
pipe 3
sw-core-01>show arp | include port1.0.19
The switch’s IP address is 192.168.120.126 and is therefore in the same broadcast domain.
You seem to have the management VLAN in a bridge. If you want to do that then apply the IP address to the management bridge. Otherwise remove the management VLAN from the bridge and leave the IP address on the VLAN interface itself.
I tried that too. but no success.
The moment I disable all VLAN interfaces (on ether1) a DHCP offer is being received on ether1 and normal Layer3 operations start.
The same goes for any DHCP client. If you have the VLAN interface in a bridge apply the DHCP client to the bridge - not the VLAN directly.
regardless that I’ve seen it working with the DHCP client on the vlan interface rather than the bridge, i have followed your advice and put all DHCP clients on bridges.
Enabling the vlan interfaces on ether1 leaves it numb, i.e. no DHCP address is being obtained.
The most recent /export compact
sep/17/2014 07:33:52 by RouterOS 6.19
/interface vlan
add disabled=yes interface=ether1 name=vlPC vlan-id=2100
add authentication-types=wpa-psk,wpa2-psk eap-methods=“”
supplicant-identity=“” wpa-pre-shared-key=whateverthatpskis
supplicant-identity=“” wpa-pre-shared-key=anotherpsk
wpa2-pre-shared-key=anotherpsk
add authentication-types=wpa2-psk eap-methods=“” management-protection=
allowed mode=dynamic-keys name=profileMasterAP supplicant-identity=“”
wpa2-pre-shared-key=“sdgf53#$hgfhryh545SRfdg$218&^%”
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g country=“new zealand” disabled=
wifiMasterAP security-profile=profileMasterAP ssid=“v-C}2#TMKw2B@7<”
wifiMasterAP name=wifiPC security-profile=profileWifiBusiness ssid=
“Skyline Business” wds-cost-range=0 wds-default-cost=0
wifiMasterAP name=wifiDMZ security-profile=profileWifiDMZ ssid=
“Skyline Enterprises” wds-cost-range=0 wds-default-bridge=brDMZ
wds-default-cost=0
/port
set 0 name=serial0
add bridge=brPCs interface=ether2
add address=192.168.120.66/26 interface=brManagement network=192.168.120.64
/ip dhcp-client
interface=brManagement use-peer-dns=no use-peer-ntp=no
interface=brPCs
/ip upnp
/system clock
set time-zone-name=Pacific/Auckland
/system ntp client
set enabled=yes primary-ntp=192.168.120.20
/tool sniffer
[admin@MikroTik] >
