RB433 losses configuration
Using a RB433AH board with OS 4.17 on and the board started loosing its settings suddenly. Was doing the same on 4.16. Wlan will disable, reset ssid back to identity value, same as reset on the wlan interface. Also funny that it resets different wlans, and only some of them at a time. Any suggestions as to why this is happening please?
