hi guys, Ive some problem with a RB433, the ether1 is broken doesnt work at all, but also it flashed the nand, can you say me another way to use ether2 for netinstall ?
thanks
thanks
It’s not possible. Fix ether1 and then reinstall RouterOS.
the problem is the switch chip I can´t get it… any other method like xmodem or netinstall via ether2 ?
I got a IP175D and changed it but doesnt work.. when the bootloader start and do POST just orange led turned on, on ether1, but in ether2 the both led works. just when u plugg onthe power
IP175C and IP175D it’s not replacement from software viewpoint.
im trying to fix the ether1 (PORT1) for later fix it the OS with netinstall. remember ive ether1 damaged
my ether2 and ether3 works but I cant install routerOS with netinstall any method to use ether2?
another thing I want to know if ether1 is connected directly to the AR71XX ? and other 2 ports through the switch chip
We found that IP175D is NOT working as expected, even on ROS 4.6… Can’t ping with large packets i.e. 65535 packet size, but you can ping with packet size less than 44000 bytes.
