RB433,NO USERMAN
Pls, Help I’m unable to access userman.
After configuring my RB433, I could not access userman.
somebody pls, help.
Userman is not a standard program. It must be downloaded from the download page.
http://www.mikrotik.com/download.html
Select the “all packages”. The “view content” link will show what is in the package, including user manager.
@SurferTim Thanks, after downloading the package, Pls I do I go about it in RB433
Upload the package file into the router (ftp), and then reboot the router.
@SurferTim, Pls put me through how to go about it. I have dowloaded the file but dont know how to upload it into my router.
I am a Linux guy, so modify to suit your ftp software. I use gFTP.
Start gFTP.
Connect to your router. Same user/password as http or ssh.
Select the package file in your computer files list.
Select upload.
Once complete, disconnect.
Then I go to my router and check.
/file print
The upgrade package should now be there. Then
/system reboot
To check if the upgrade was successful after the reboot,
/file print
The upgrade package file should be gone.
@SurferTim, can it be done through GUI winbox.
In a way. If you have an ftp server with the upgrade package on it, you can use
/tool fetch
on the router.
