RB433 not responding
Hello to everybody.
I happened to have to manage a bunch of RB433. I have one of those that seems bricked, or something like that.
What happens is that it seems to boot correctly (first beep, then some led blinking, then three beeps after a little while), and the leds on the ethernet ports blink normally when a cable is inserted.
The problem is that I cannot access it in order to reconfigure it.
As I have succesfully done on other RB433, I tried to reset it with the jumper hole, but this particular board seems to be resilient to resetting…
The board is not on 192.168.88.1, nor on its previous network, nor it responds to Winbox using the MAC address. I even tried a serial connection but to no avail.
Do you have some suggestion?
Thanks in advance,
Isidoro
