Hi
Hopefulle some1 can help me with this.
I have 11 PPPoE connections on ether1 and they are routed to different ports on ether2+wlan1(bridge1).
eg ppp1 to 2000, ppp2 to 2001, ppp3 to 2003. PPP will work normal without being forwarded to a port.
For some reason there is always two PPPoE connections going to one port and want to get this right.
PPP and any random PPPoE connection will route to the same port.
0 R ether1 ether 1500
1 R ether2 ether 1500
2 X ether3 ether 1500
3 R ppp pppoe-out 1480
4 wlan1 wlan 1500
5 R bridge1 bridge 1500
6 X ppp2 pppoe-out
7 X ppp1 pppoe-out
8 X ppp3 pppoe-out
9 X ppp4 pppoe-out
10 X ppp5 pppoe-out
11 X ppp6 pppoe-out
12 X ppp7 pppoe-out
13 X ppp8 pppoe-out
14 X ppp9 pppoe-out
15 X ppp10 pppoe-out
10 of the PPPoE connections are dissabled at the moment until I can get it fixed. The 10 connections are also displayed in blue and I dont know why. Is that because they have the same gateway?
How can I prevent two PPPoE connections from being routed to the same port?
Thanks in advance
