RB433 system problem
Hello everyone,
We have problems with two RB433s. After installing dude mipsbe packages on them, there are no free space available on the memory. I can not upgrade RoS version or make backup configuration. I can not restore old configuration or uninstall any of the packages, can’t remove user manager or dude package because as I can see, only those two packages require store on memory of RBs. I can’t make supout.rif file on any of RBs.
One of these RBs won’t boot after rebooting.
Can you give me more directions where I can go or something? How can I uninstall packages successfully under this condition to get more space available?
Problem solved, I bought new ones.
Thanks for help. :confused:
in these cases fall back to basics - try to reinstall router using netinstall. As this tool will save your configuration, wipe clean your router and install packages you required and then reapply configuration (that is, if you requested to save old configuration)
Thanks for replying, I tried to reinstall using netinstall but RB couldn’t bee recognized by netinstall so I sent it to distributor due the complain issues.
