rb433, which ports is wan2
I have rb433 i just deployed with 3 cards in it. the middle m-pci slot is occupied by a 5ghz card and that comes up in ros 3.13 as wlan1
which slot would be wlan3 and which wlan2?
I just cant access the physical box right now
thanks
When you double click on wlan1 or wlanx you see PCI info in tab general. I think, its the location of minipci card. Its for example 00:12.0 or 00:13.0 or 00:14.0 in my 433ah. Maybe when you put pci card in any slot, ir just marks it wlan1 and when you put other it marks it wlan2. So its not strictly dependent on slot.
well all 3 cards were put in at the same time..adn then the unit wsa booted and loaded up.
the pci info doesnt really help bc thats the same as the wlan number..
any chance MT could chime in??
