I’m having some problems in configuring some Router Board 433s to perform as shown in the attached file wlangateway.png.
I currently have this working using one RB433 for the gateway and three other RB433s, using eth1 and eth2, for the NAT. But this is all connected via cat5 cable. What I would like to do, is remove the cabling from the gateway to the routers by using the Atheros AR5413 cards via wlan1. So far I have had no success. Is this possible? And what are the configuration steps required?
Any help will be greatly appreaciated.
