RB433 with 2 wlanx kernel failure
Hello, I now have the certainty of a probable error in the ROS version 6.19, we have two different situations made ​​them both with RB433 with two R52Hns, one of which is configured as ApBridge and the second as StationBridge for P2P link. it is common during the day in the log there is a kernel failure and sometimes a reboot of the system given by a kernel failure. I have eliminated the second wlan and the situation seems to have stabilized have you encountered this problem?
cetalfio
Do netinstall procedure for solved this problem
http://www.wirelessinfo.be/index.php/mikrotik/pages/netinstalle
caution! you lose your configuration
if you can take export from your configuration
Thanks plisken but netinstall is not a solution, two RB433 with the same setting (first wlan AP and second Station Bridge) has the same problem. If I disable the Station Bridge wlan the problem disappears.
cetalfio
kernel failure = software problem
Try netinstall with 6.20
Have you update the bios to?
