rb433 with 35 KM distance recive bandwidth and not send
Dears
good day
i have link point to point 35 KM using rb433 with minipci X5 600 mw
i get the good signal -65 dbm and rb433 AP and another wds station
if perform the bandwidth test from wds station the resive is okay but the send bamdwidth test act disconnect the rb433
please any prof. have solve this problem???
Did you tried to make a test pc to pc? Or pc to remote routerboard?
you must trying bandwidth test running first also ping to remote routerboard or pc, then you can select sent, receive or both while you can see if traffic download / receive running well then if sent not running and the ping is request time out , so i think you must configure wireless channel and data rate to gain best and fit configuration.TIA
Regards,
Ojie Nugraha
