RB433
before i deploy i want to ask you a question,
i have one groove one one side and on the other side a rb433 with a MikroTik R52nM 802.11a/b/g/n dual band miniPCI card , and i want to make a ptp link! the distance is 50 meters line of sight no big deal..the thing im worried is that the rb433 has 300mhz cpu…how much bandwidth can this cpu take?? on the other side (groove side) is a vdsl 50mbps, will i have this speed ??
groove and rb433 will bridging connection
thanks
If you only do the bridging, no CPU will be a bottleneck. Both groove and rb433 can do more than 50mbit/s in a bridge setup like this.
thanks for your quick answer ! now up in the roof for deployment!!
