RB433
hello how can i limit data rate for any user that connect wireless from RB433 if i have user ip.
Look at this. It should do what you need.
http://wiki.mikrotik.com/wiki/Manual:Queue#Simple_Queues
from winbox open queues on left side.
click the + sign on upper left of screen.
type in a name for this user.
BE SURE to pit the ip address in target address space or all users will be set to this speed.
set the limit in the blocks for target upload and target download.
if the speed is not listed in pull down block the type in the speed. ex 1500k is 1.5 mb
click apply and/or ok and it is set
i hope this helps
thanks
hello,i have ahardware problem where my RB433 is switch on but any ether (1,2 nor 3)it operate.what happened with it?
